Ir para o conteúdo principal
HP Photosmart D110a Scanner Glass Replacement
O que você precisa
  1. HP Photosmart D110a Scanner Glass Replacement, Printer Hood Assembly: passo 1, imagem 1 %32
    • First, begin by removing the printer's hood.
    • Open the printer's mouth by simply pulling down on it; there are 2 mouth pieces that need to be pulled down.
    • Adjust the flap covering the scanner upward, as shown.
  2. HP Photosmart D110a Scanner Glass Replacement: passo 2, imagem 1 %32
    • Remove the flap for the scanner. The flap is attached with two clips that can be dislodged by pulling lightly away from the printer.
  3. HP Photosmart D110a Scanner Glass Replacement: passo 3, imagem 1 %32
    • Locate the three screws on top of the printer.
    • The orange circle shows a fourth screw located behind the power panel. Directions to remove this screw are in a later step.
  4. HP Photosmart D110a Scanner Glass Replacement: passo 4, imagem 1 %32 HP Photosmart D110a Scanner Glass Replacement: passo 4, imagem 2 %32 HP Photosmart D110a Scanner Glass Replacement: passo 4, imagem 3 %32
    • Remove the three screws from the top of the printer with a T-9 screwdriver as shown.
  5. HP Photosmart D110a Scanner Glass Replacement: passo 5, imagem 1 %32 HP Photosmart D110a Scanner Glass Replacement: passo 5, imagem 2 %32
    • To access and remove the fourth and final screw attaching the hood, the panel for the power button must be removed as follows:
    • Reach into the mouth of the printer and press on the small clip behind the power button. This allows the panel of the power button to be removed.
    • A picture of the power button panel removed is provided to show the location of the clip that needs to be pressed.
    • After pressing the clip, pull out the power button panel by pulling from right to left.
  6. HP Photosmart D110a Scanner Glass Replacement: passo 6, imagem 1 %32 HP Photosmart D110a Scanner Glass Replacement: passo 6, imagem 2 %32
    • Remove the exposed screw that was covered by the power button panel.
    • Do not try and torque the screw from an angle. This will ruin the screw's head, and make it even more difficult to remove the screw. Only remove it as already described.
    • This screw is placed awkwardly. We found holding a T9 bit in a pair of needle nose pliers gave us enough leverage to pull it up.
  7. HP Photosmart D110a Scanner Glass Replacement: passo 7, imagem 1 %32 HP Photosmart D110a Scanner Glass Replacement: passo 7, imagem 2 %32 HP Photosmart D110a Scanner Glass Replacement: passo 7, imagem 3 %32
    • This step is easier with two people. Carefully have one person lift the hood of the printer 2-3 inches above where it was resting.
    • Remove the ribbon cables and wires attaching the motherboard (the only green PCB board) to the hood by gently pulling upward on them.
    • When all three cables are removed, lift the hood away from the printer and set it aside.
  8. HP Photosmart D110a Scanner Glass Replacement, Disassembling HP Photosmart D110a Printer Hood: passo 8, imagem 1 %32 HP Photosmart D110a Scanner Glass Replacement, Disassembling HP Photosmart D110a Printer Hood: passo 8, imagem 2 %32 HP Photosmart D110a Scanner Glass Replacement, Disassembling HP Photosmart D110a Printer Hood: passo 8, imagem 3 %32
    • After being separated from the printer, the hood is ready to be disassembled.
    • Remove the only screw on the printer hood's underside, as shown. Use a T-9 screwdriver.
  9. HP Photosmart D110a Scanner Glass Replacement: passo 9, imagem 1 %32 HP Photosmart D110a Scanner Glass Replacement: passo 9, imagem 2 %32
    • With the screw removed, separate the two pieces of the hood by lifting it vertically.
    • Only lift the the top piece enough so that there is no tension applied to the ribbon cables shown.
    • Carefully pull down the white ribbon cable through the top piece of the hood.
  10. HP Photosmart D110a Scanner Glass Replacement: passo 10, imagem 1 %32 HP Photosmart D110a Scanner Glass Replacement: passo 10, imagem 2 %32
    • Carefully separate the two hood pieces connected by the black ribbon.
    • Set the piece of the hood down such that no stress is applied to the scanner as it is attached by ribbon cable.
    • The printer hood should now be in 2 pieces.
    hi, can assist me on how to replace encoder strip hp d110a. thanks
    Rufai Yusuf - Responder
  11. HP Photosmart D110a Scanner Glass Replacement, Scanner Glass: passo 11, imagem 1 %32 HP Photosmart D110a Scanner Glass Replacement, Scanner Glass: passo 11, imagem 2 %32
    • The scanner glass is held down by one T-9 screw. Use a screw driver to remove the screw.
  12. HP Photosmart D110a Scanner Glass Replacement: passo 12, imagem 1 %32 HP Photosmart D110a Scanner Glass Replacement: passo 12, imagem 2 %32
    • Once the screw has been taken out, lift the glass covering from the bottom left corner as shown.
    • The other corner of the glass can now be lifted up as well. Use the two corners to lift up the whole scanner glass.
Conclusão
4 outras pessoas executaram este guia.
Tim Wise
Membro desde: 04/01/11
173 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 10-38, Forte Spring 2011 Membro de Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
Membros da 5
Autoria de 10 guias
5 comentários
Very helpful guide, the scanner glass was dirty from inside, so the guide was able to give me clear instructions how to proceed with the openning. Thanks!
Alexandre Silva - Responder
Very helpful in most ways. I needed to clean the inside of the glass because the ribbon cable was leaving a discoloration when traveling and showed up on my scanned documents. I actually did this solo and was fine until reassemble faze when the actual scanner bar would not stay in place to reassemble the two parts. I finally got it back together after much profanity and no small amount of patients. The next dilemma was the reassembly of top to bottom which was easily fixed with a small piece of duct tape holding The right side in place while reconnecting the two ribbon cables and the power connector. All is back together and working fine. My thanx to my God and to you for a successful fix.
keith mcguire - Responder
I found that it was actually a T10 bit on mine as well and found when removing the 3 screws shown in red a 2” bit works best but with the one marked in orange under the power button a 1” if placed in the screw first then pulled forward slightly I was able to use a 1/4” drive screwdriver on a slight angle which made it much faster to remove that one screw. That being said, still a very helpful fix to a problem that was really frustrating me as I kept cleaning the top of the glass until I realized the problem was on the underside.
As an after thought, if it were me I would have designed the scanner portion so that less effort would be needed to clean both sides of the glass like screws or clips that can be accessed just by lifting the door on the top.
These instructions are very good and I was able to do this with my husbands help. With one except it doesn’t mention if the new scanner glass has a right side or a wrong side to it. Does it matter at all which side goes up and which side goes down?
Thank you
Bonnie
Yvonne Nielsen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 6,073
