Introdução
Considering the steps in this guide were completed by 2 people, it is recommended to attempt this guide with 2 or more people.
Required Tools
- T-9 Screwdriver
- Needle-Nose Pliers
O que você precisa
First, begin by removing the printer's hood.
Open the printer's mouth by simply pulling down on it; there are 2 mouth pieces that need to be pulled down.
Adjust the flap covering the scanner upward, as shown.
To access and remove the fourth and final screw attaching the hood, the panel for the power button must be removed as follows:
Reach into the mouth of the printer and press on the small clip behind the power button. This allows the panel of the power button to be removed.
After pressing the clip, pull out the power button panel by pulling from right to left.
This step is easier with two people. Carefully have one person lift the hood of the printer 2-3 inches above where it was resting.
Remove the ribbon cables and wires attaching the motherboard (the only green PCB board) to the hood by gently pulling upward on them.
When all three cables are removed, lift the hood away from the printer and set it aside.
After being separated from the printer, the hood is ready to be disassembled.
Remove the only screw on the printer hood's underside, as shown. Use a T-9 screwdriver.
The LCD is attached to the hood by two slots as shown in red. Push the sloped slides of the slots inward to release the slots from the hood.
