Ir para o conteúdo principal
HP Photosmart D110a Ink Cartridge Replacement
  1. HP Photosmart D110a Ink Cartridge Replacement, Ink Cartridge: passo 1, imagem 1 %32
    • In order to remove the old cartridge, open the mouth of the printer by pulling down on it.
    • There are two pieces to the mouth, make sure to pull down both.
  2. HP Photosmart D110a Ink Cartridge Replacement: passo 2, imagem 1 %32 HP Photosmart D110a Ink Cartridge Replacement: passo 2, imagem 2 %32
    • Press down on the head of the ink cartridge that needs replacing. This will release the cartridge and allow you to pull it out.
    • Remember the orientation of the old cartridge. The new cartridge will be placed in the slot with the same orientation.
  3. HP Photosmart D110a Ink Cartridge Replacement: passo 3, imagem 1 %32
    • Place the new cartridge into the slot and press firmly until it pops into place.
Conclusão
Tim Wise
Membro desde: 04/01/11
173 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 10-38, Forte Spring 2011 Membro de Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
Membros da 5
Autoria de 10 guias
2 comentários
This DID NOT work. My fingers are are practically bleeding. Please please...there must be another way
April - Responder
the HP ink cartridge is 60. Does that make any difference???
April -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 21
Duração total: 12,155
