Ir para o conteúdo principal
HP Photosmart 935 Plastic Casing Replacement
O que você precisa
  1. HP Photosmart 935 Plastic Casing Replacement, Batteries: passo 1, imagem 1 %32 HP Photosmart 935 Plastic Casing Replacement, Batteries: passo 1, imagem 2 %32
    • Flip the camera over so the bottom of the camera is facing you.
    • Turn the mode dial to the OFF position.
  2. HP Photosmart 935 Plastic Casing Replacement: passo 3, imagem 1 %32 HP Photosmart 935 Plastic Casing Replacement: passo 3, imagem 2 %32
    • Slide the bottom cover in the direction of the arrow to open it.
  3. HP Photosmart 935 Plastic Casing Replacement: passo 4, imagem 1 %32
    • Pull out the batteries.
  4. HP Photosmart 935 Plastic Casing Replacement, Plastic Casing: passo 5, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
  5. HP Photosmart 935 Plastic Casing Replacement: passo 6, imagem 1 %32 HP Photosmart 935 Plastic Casing Replacement: passo 6, imagem 2 %32
    • Remove the four 4.7 mm screws on the left side of the camera.
  6. HP Photosmart 935 Plastic Casing Replacement: passo 7, imagem 1 %32 HP Photosmart 935 Plastic Casing Replacement: passo 7, imagem 2 %32
    • Remove the four 4.7 mm screws on the opposite side of the camera.
  7. HP Photosmart 935 Plastic Casing Replacement: passo 8, imagem 1 %32 HP Photosmart 935 Plastic Casing Replacement: passo 8, imagem 2 %32 HP Photosmart 935 Plastic Casing Replacement: passo 8, imagem 3 %32
    • Use your thumbs to pry the case apart.
    • It is easiest to pry the case apart if you start at the bottom.
    • The case should come apart with minimal effort. If it doesn't, you can use a spudger or plastic opening tool to pry it open.
  8. HP Photosmart 935 Plastic Casing Replacement: passo 9, imagem 1 %32
    • This step requires a significant amount of force.
    • Pull the bottom half of the inner camera out of the case by half an inch. This may be difficult.
  9. HP Photosmart 935 Plastic Casing Replacement: passo 10, imagem 1 %32 HP Photosmart 935 Plastic Casing Replacement: passo 10, imagem 2 %32
    • While pulling the camera out of the case, note the small soft plastic cover on the side. This cover will detach from the rest of the device.
    • Once the bottom of the inner camera is pulled out, pull the device out completely.
    • Use a firm grasp when removing the device from the case for stability and control.
Conclusão
Clay Young
Membro desde: 04/04/12
233 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 15-13, Forte Spring 2012 Membro de Cal Poly, Team 15-13, Forte Spring 2012
CPSU-FORTE-S12S15G13
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 8
Duração total: 1,733
