Introdução
To detach the memory you will need a Phillips PH1 screwdriver. Also remember to be gentle with the screws because not all of them will completely detach from the plastic.
O que você precisa
Shut down the computer.
Turn computer upside down so the base is facing upward.
Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
Slide cover toward empty battery area and remove it.
Quase terminado!
Conclusão
