Introdução
To remove the hard drive you will need a Phillips PH1 screw driver. Caution not all screws will completely detach.
O que você precisa
Shut down the computer.
Turn computer upside down so the base is facing upward.
Position the computer so the front is towards you.
Remove two 5mm Phillips #1 screws
Slide the hard drive cover towards the empty battery spot and remove it.
Quase terminado!
Conclusão
