Ir para o conteúdo principal
HP Pavillion dm4t-2100 Finger Print Scanner Replacement
O que você precisa
  1. HP Pavillion dm4t-2100 Finger Print Scanner Replacement, Battery: passo 1, imagem 1 %32 HP Pavillion dm4t-2100 Finger Print Scanner Replacement, Battery: passo 1, imagem 2 %32
    • Shut down the computer.
    • Shutting down the computer by holding power button can cause damage to computer.
    • Turn computer upside down so the base is facing upward.
  2. HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 2, imagem 1 %32 HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 2, imagem 2 %32 HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 2, imagem 3 %32
    • Slide latch next to battery icon until battery pops up.
    • Pull the battery away from the computer until completely detached.
  3. HP Pavillion dm4t-2100 Finger Print Scanner Replacement, Hard Drive: passo 3, imagem 1 %32 HP Pavillion dm4t-2100 Finger Print Scanner Replacement, Hard Drive: passo 3, imagem 2 %32 HP Pavillion dm4t-2100 Finger Print Scanner Replacement, Hard Drive: passo 3, imagem 3 %32
    • Position the computer so the front is towards you.
    • Remove two 5mm Phillips #1 screws
    • Slide the hard drive cover towards the empty battery spot and remove it.
  4. HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 4, imagem 1 %32 HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 4, imagem 2 %32 HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 4, imagem 3 %32
    • Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
    • Slide cover toward empty battery area and remove it.
  5. HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 5, imagem 1 %32
    • Disconnect the hard drive cable that is plugged in.
    • Lift the tab on the hard drive to pull it out of the computer.
    • Hard Drive is removed.
  6. HP Pavillion dm4t-2100 Finger Print Scanner Replacement, Finger Print Scanner: passo 6, imagem 1 %32 HP Pavillion dm4t-2100 Finger Print Scanner Replacement, Finger Print Scanner: passo 6, imagem 2 %32 HP Pavillion dm4t-2100 Finger Print Scanner Replacement, Finger Print Scanner: passo 6, imagem 3 %32
    • Remove one 5mm Phillips #1 Screw that is securing the optical drive.
    • With the nylon spudger push the optical drive until you can grab it.
    • Pull the optical drive all the way out, until removed.
  7. HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 7, imagem 1 %32
    • Remove two 6.5mm Phillips #1 screws from the back of the computer.
    • Keyboard icons next to keyboard bolts
  8. HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 8, imagem 1 %32
    • Turn the computer upside down with the front towards you, and, remove the two rubber feet near the battery.
    • Organizing screws would be helpful
    • Remove 13 Phillips M2.0X7.0 screws.
    • Remove 6 Phillips M2.0X2.0 broad head screws.
  9. HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 9, imagem 1 %32 HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 9, imagem 2 %32
    • Turn the computer over, and open the computer as far as possible without breaking it.
    • Release the top of the keyboard by lifting up and gently pull the top up until the whole keyboard is up.
    • Lift plastic cover to release the ZIF connector that is holding the keyboard in place. Then remove the keyboard.
  10. HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 10, imagem 1 %32 HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 10, imagem 2 %32
    • Remove four 4mm Phillips #0 screws near the top of the keyboard area.
    • Lift top cover from the base and release the ZIF connector that the power button is connected to. The cover should now be removed.
    • Using a nylon spudger could be helpful
  11. HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 11, imagem 1 %32
    • Release 2 ZIF connectors where the touch pad cable and fingerprint reader are connected.
  12. HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 12, imagem 1 %32 HP Pavillion dm4t-2100 Finger Print Scanner Replacement: passo 12, imagem 2 %32
    • Take the top cover and put it upside down and remove one 3mm Phillips #1 screw.
    • Release ZIF connector on fingerprint reader and remove.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 539
