Ir para o conteúdo principal
HP Pavillion dm1-3010nr Keyboard Replacement
O que você precisa
  1. HP Pavillion dm1-3010nr Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Flip the device over, so that the bottom cover is exposed.
    • Slide the black locking mechanism into its unlock position.
  2. HP Pavillion dm1-3010nr Keyboard Replacement: passo 2, imagem 1 %32
    • After unlocking the mechanism, slide the battery out of its compartment.
  3. HP Pavillion dm1-3010nr Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Remove the black bottom cover by using your fingernails or a thin flat tool.
  4. HP Pavillion dm1-3010nr Keyboard Replacement: passo 4, imagem 1 %32 HP Pavillion dm1-3010nr Keyboard Replacement: passo 4, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove three 5mm screws securing the keyboard.
    • The screws to be removed are circled in red in the picture provided.
    • Make sure to place the screws somewhere safe like on top of a magnet.
  5. HP Pavillion dm1-3010nr Keyboard Replacement: passo 5, imagem 1 %32
    • Flip the laptop so that they keyboard is facing you.
    • Use a thin and flat metal to carefully lift up the top side of the keyboard and separate it from the top cover.
  6. HP Pavillion dm1-3010nr Keyboard Replacement: passo 6, imagem 1 %32 HP Pavillion dm1-3010nr Keyboard Replacement: passo 6, imagem 2 %32
    • Now you will see the keyboard cable connector attached to a locking tab.
    • Lift up the locking tab with a thin and flat screwdriver or your fingernail.
    • The locking tab will open up at a 90 degree angle.
    • Pull the keyboard cable from the connector.
Conclusão
Rosalia Olga Dupont Ayala
Membro desde: 10/22/18
210 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S7-G1, Lore Fall 2018 Membro de UC Davis, Team S7-G1, Lore Fall 2018
UCD-LORE-F18S7G1
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 13
Duração total: 644
