Ir para o conteúdo principal
HP Pavillion G7-2235DX Keyboard Replacement
O que você precisa
  1. HP Pavillion G7-2235DX Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Before beginning, make sure the computer is turned off and the charger is disconnected.
    • Flip the computer over, so that the bottom is facing up.
  2. HP Pavillion G7-2235DX Keyboard Replacement: passo 2, imagem 1 %32
    • To remove the battery, slide the battery switch to the left.
  3. HP Pavillion G7-2235DX Keyboard Replacement: passo 3, imagem 1 %32 HP Pavillion G7-2235DX Keyboard Replacement: passo 3, imagem 2 %32
    • Using a PH Screwdriver, remove the three 7.25mm screws located on the bottom panel.
    • After removing all screws, remove the panel by sliding down.
  4. HP Pavillion G7-2235DX Keyboard Replacement: passo 4, imagem 1 %32
    • Using a PH screwdriver, remove the screw adjacent to the white labels.
    • There is a keyboard icon next to the screw
  5. HP Pavillion G7-2235DX Keyboard Replacement: passo 5, imagem 1 %32
    • Flip the laptop over, and open it.
  6. HP Pavillion G7-2235DX Keyboard Replacement: passo 6, imagem 1 %32
    • Using a plastic spudger, pry beneath the keyboard near the "delete" key, and pop the keyboard up from the laptop.
    • From the open gap, continue to pry around the perimeter of the keyboard, separating it from the laptop.
  7. HP Pavillion G7-2235DX Keyboard Replacement: passo 7, imagem 1 %32 HP Pavillion G7-2235DX Keyboard Replacement: passo 7, imagem 2 %32
    • Using both hands, carefully lift the keyboard off of the laptop.
    • There may be a ribbon attached. If so, gently pull the ribbon cable up and away from the connector.
Conclusão
5 outras pessoas executaram este guia.
Bre'Anna Sanders
Membro desde: 10/11/16
113 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-7, Leahy Fall 2016 Membro de USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 87
Duração total: 2,625
