Ir para o conteúdo principal
HP Pavillion 15-ay041wm Speakers Replacement
O que você precisa
  1. HP Pavillion 15-ay041wm Speakers Replacement, Battery: passo 1, imagem 1 %32 HP Pavillion 15-ay041wm Speakers Replacement, Battery: passo 1, imagem 2 %32
    • Place the laptop upside down.
  2. HP Pavillion 15-ay041wm Speakers Replacement: passo 2, imagem 1 %32 HP Pavillion 15-ay041wm Speakers Replacement: passo 2, imagem 2 %32
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. HP Pavillion 15-ay041wm Speakers Replacement: passo 3, imagem 1 %32 HP Pavillion 15-ay041wm Speakers Replacement: passo 3, imagem 2 %32 HP Pavillion 15-ay041wm Speakers Replacement: passo 3, imagem 3 %32
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. HP Pavillion 15-ay041wm Speakers Replacement, Disc Drive: passo 4, imagem 1 %32
    • Turn the laptop upside down with the base of the laptop facing you.
    • Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
    • Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
  5. HP Pavillion 15-ay041wm Speakers Replacement: passo 5, imagem 1 %32 HP Pavillion 15-ay041wm Speakers Replacement: passo 5, imagem 2 %32 HP Pavillion 15-ay041wm Speakers Replacement: passo 5, imagem 3 %32
    • Press the eject button.
    • Hold and carefully slide the disc drive out of the laptop.
  6. HP Pavillion 15-ay041wm Speakers Replacement, Keyboard: passo 6, imagem 1 %32 HP Pavillion 15-ay041wm Speakers Replacement, Keyboard: passo 6, imagem 2 %32 HP Pavillion 15-ay041wm Speakers Replacement, Keyboard: passo 6, imagem 3 %32
    • Using the Jimmy, create a separation between the keyboard and bottom panel.
    • Slide around the body of the panel until the separation is big enough for you to use your fingers.
    • Separate the keyboard and bottom panel.
  7. HP Pavillion 15-ay041wm Speakers Replacement, Speakers: passo 7, imagem 1 %32 HP Pavillion 15-ay041wm Speakers Replacement, Speakers: passo 7, imagem 2 %32 HP Pavillion 15-ay041wm Speakers Replacement, Speakers: passo 7, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, disconnect the left speakers from the motherboard.
    • Remove the left and right speakers from the laptop.
  8. HP Pavillion 15-ay041wm Speakers Replacement: passo 8, imagem 1 %32 HP Pavillion 15-ay041wm Speakers Replacement: passo 8, imagem 2 %32
    • Slide the wires connecting both speakers out from the black stoppers.
    • You can now replace the speakers.
Conclusão
Olutola Yerokun Ty
Membro desde: 01/16/20
135 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 161
