Ir para o conteúdo principal
HP Pavilion zv5000 Screen Replacement
O que você precisa
  1. HP Pavilion zv5000 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Make sure that your device is properly shut down and unplugged from any outlet.
    • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
  2. HP Pavilion zv5000 Screen Replacement: passo 2, imagem 1 %32 HP Pavilion zv5000 Screen Replacement: passo 2, imagem 2 %32
    • Press and slide up the battery release tab with your thumb until the battery pops out of place.
  3. HP Pavilion zv5000 Screen Replacement: passo 3, imagem 1 %32 HP Pavilion zv5000 Screen Replacement: passo 3, imagem 2 %32
    • Using two fingers, pry the rest of the battery out of the socket.
  4. HP Pavilion zv5000 Screen Replacement, Keyboard: passo 4, imagem 1 %32 HP Pavilion zv5000 Screen Replacement, Keyboard: passo 4, imagem 2 %32
    • Using a Phillips #0 screwdriver, unscrew all four Phillips PM 2.5X13.0mm screws and place in a secure area until the end of the project.
  5. HP Pavilion zv5000 Screen Replacement: passo 5, imagem 1 %32
    • Flip laptop back over and open as far as it can go.
  6. HP Pavilion zv5000 Screen Replacement: passo 6, imagem 1 %32
    • Use the flat edge of the plastic spudger inserted under the bottom of the strip cover and pry upwards to un-clip the cover, starting at the right and moving to the left.
    • If the plastic spudger is not doing the trick, try using the metal spudger careful to not pop any keys out.
  7. HP Pavilion zv5000 Screen Replacement: passo 7, imagem 1 %32 HP Pavilion zv5000 Screen Replacement: passo 7, imagem 2 %32
    • Use hands to completely lift off the strip cover and remove.
  8. HP Pavilion zv5000 Screen Replacement: passo 8, imagem 1 %32
    • Use the Phillips #0 screwdriver again, unscrew all four Phillips PM 2.5X13.0mm screws from the top of the keyboard and set aside.
  9. HP Pavilion zv5000 Screen Replacement: passo 9, imagem 1 %32 HP Pavilion zv5000 Screen Replacement: passo 9, imagem 2 %32
    • Using your hands, lift the keyboard up from the top towards yourself until the keyboard is resting in your hand.
    • Do not aggressively pull at the keyboard for risk of ripping the connector cable.
  10. HP Pavilion zv5000 Screen Replacement: passo 10, imagem 1 %32 HP Pavilion zv5000 Screen Replacement: passo 10, imagem 2 %32
    • Gently slide out the connecting cable from the laptop to the keyboard.
    • Do not aggressively pull at the connecting cable.
  11. HP Pavilion zv5000 Screen Replacement: passo 11, imagem 1 %32
    • Completely remove the keyboard from the rest of the laptop.
  12. HP Pavilion zv5000 Screen Replacement, Screen: passo 12, imagem 1 %32
    • Flip the Pavilion back over on its backside.
  13. HP Pavilion zv5000 Screen Replacement: passo 13, imagem 1 %32 HP Pavilion zv5000 Screen Replacement: passo 13, imagem 2 %32 HP Pavilion zv5000 Screen Replacement: passo 13, imagem 3 %32
    • Using the same Phillips #0 screwdriver, unscrew the six Phillips PM 2.5X6.0mm screws.
    • Also remove the four Phillips PM 2.5X13.0mm screws to remove the thermal plate with the same screwdriver.
  14. HP Pavilion zv5000 Screen Replacement: passo 14, imagem 1 %32 HP Pavilion zv5000 Screen Replacement: passo 14, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Flip the laptop back over and open the lid all the way.
    • Using the flat edge of the plastic spudger, pry straight up to remove the Mini PCI Connector Cables from the board.
    • Tweezers can also be used to gently squeeze and pull up on the Mini PCI Cable Connectors to remove from the board.
    • When reinstalling, place the Mini PCI Connector Cables back in place and gently press straight down until they snap into place.
  15. HP Pavilion zv5000 Screen Replacement: passo 15, imagem 1 %32 HP Pavilion zv5000 Screen Replacement: passo 15, imagem 2 %32 HP Pavilion zv5000 Screen Replacement: passo 15, imagem 3 %32
    • Using the tweezers, gently squeeze and pull backwards on the display cable until it is disconnected.
    • To reinsert, simply align the display cable to its proper spot and gently push into place.
  16. HP Pavilion zv5000 Screen Replacement: passo 16, imagem 1 %32 HP Pavilion zv5000 Screen Replacement: passo 16, imagem 2 %32
    • Use the Phillips #0 screwdriver again to remove the four Phillips 2.5X13.0mm screws that hold the clips for the screen into place.
  17. HP Pavilion zv5000 Screen Replacement: passo 17, imagem 1 %32 HP Pavilion zv5000 Screen Replacement: passo 17, imagem 2 %32
    • Turn the laptop around until the top cover is facing you. Keep the laptop in an open position.
    • Unscrew the four Phillips PM 2.5X6.0mm screws using the Phillips #0 that hold the clips of the screen on to the base.
  18. HP Pavilion zv5000 Screen Replacement: passo 18, imagem 1 %32
    • Firmly grasp the top of the screen with your hands and pull towards you and upwards to remove the screen from the base.
Conclusão
Eliza Marks
Membro desde: 10/18/16
649 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 4-6, Catania Fall 2016 Membro de UMass Dartmouth, Team 4-6, Catania Fall 2016
UMASSD-CATANIA-F16S4G6
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 1,250
