Ir para o conteúdo principal
HP Pavilion zv5000 Battery Replacement
  1. HP Pavilion zv5000 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure that your device is properly shut down and unplugged from any outlet.
    • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
  2. HP Pavilion zv5000 Battery Replacement: passo 2, imagem 1 %32 HP Pavilion zv5000 Battery Replacement: passo 2, imagem 2 %32
    • Press and slide up the battery release tab with your thumb until the battery pops out of place.
  3. HP Pavilion zv5000 Battery Replacement: passo 3, imagem 1 %32 HP Pavilion zv5000 Battery Replacement: passo 3, imagem 2 %32
    • Using two fingers, pry the rest of the battery out of the socket.
Conclusão
Eliza Marks
Membro desde: 10/18/16
649 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 4-6, Catania Fall 2016 Membro de UMass Dartmouth, Team 4-6, Catania Fall 2016
UMASSD-CATANIA-F16S4G6
3 Membros
Autoria de 5 guias
2 comentários
White light comes on when it is charging
Sandy Hancock - Responder
White light comes on the computer if it is charging
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 1,064
