Ir para o conteúdo principal
HP Pavilion ze4530US Keyboard Replacement
O que você precisa
  1. HP Pavilion ze4530US Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Unscrew all screws on the back of the laptop.
    • There should be a total of 22 screws.
  2. HP Pavilion ze4530US Keyboard Replacement: passo 2, imagem 1 %32 HP Pavilion ze4530US Keyboard Replacement: passo 2, imagem 2 %32
    • Remove all the protective covers such as the RAM protective cover.
    • Then remove the battery by pushing up on the battery release switch and pull the battery out.
  3. HP Pavilion ze4530US Keyboard Replacement: passo 3, imagem 1 %32
    • Wedge open the top panel located above the keyboard.
    • This piece will not come off.
    • 5 screws should be visible under the lifted panel. Unscrew all screws attaching the keyboard to the laptop.
  4. HP Pavilion ze4530US Keyboard Replacement: passo 4, imagem 1 %32
    • Once all the screws are taken out of the top portion of the keyboard, wedge open the keyboard on all sides of the keyboard.
  5. HP Pavilion ze4530US Keyboard Replacement: passo 5, imagem 1 %32
    • Lift the keyboard and unplug it out of the socket.
  6. HP Pavilion ze4530US Keyboard Replacement: passo 6, imagem 1 %32
    • You have successfully removed the keyboard.
Conclusão
Sonny Sem
Membro desde: 10/11/16
356 Reputação
Autoria de 3 guias
Equipe
Texas Tech, Team 38-5, Bennett Fall 2016 Membro de Texas Tech, Team 38-5, Bennett Fall 2016
TTU-BENNETT-F16S38G5
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 154
