Ir para o conteúdo principal
HP Pavilion zd8000 Switch Cover Replacement
O que você precisa
  1. HP Pavilion zd8000 Switch Cover Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Switch Cover Replacement: passo 2, imagem 1 %32 HP Pavilion zd8000 Switch Cover Replacement: passo 2, imagem 2 %32
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Switch Cover Replacement, WiFi Card Cables: passo 3, imagem 1 %32 HP Pavilion zd8000 Switch Cover Replacement, WiFi Card Cables: passo 3, imagem 2 %32
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  4. HP Pavilion zd8000 Switch Cover Replacement: passo 4, imagem 1 %32 HP Pavilion zd8000 Switch Cover Replacement: passo 4, imagem 2 %32
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
  5. HP Pavilion zd8000 Switch Cover Replacement, Switch Cover: passo 5, imagem 1 %32 HP Pavilion zd8000 Switch Cover Replacement, Switch Cover: passo 5, imagem 2 %32
    • Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
    • Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
  6. HP Pavilion zd8000 Switch Cover Replacement: passo 6, imagem 1 %32
    • Flip the laptop over.
    • Fully open the laptop.
  7. HP Pavilion zd8000 Switch Cover Replacement: passo 7, imagem 1 %32 HP Pavilion zd8000 Switch Cover Replacement: passo 7, imagem 2 %32 HP Pavilion zd8000 Switch Cover Replacement: passo 7, imagem 3 %32
    • Rotate it so the display is on your right and the keyboard is on your left.
    • Lift the switch cover firmly but slowly so you do not snap it.
    • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
    • The switch cover should easily separate from the laptop as you run the spudger through.
Conclusão
Uma outra pessoa concluiu este guia.
Allie Menard
Membro desde: 04/12/11
820 Reputação
Autoria de 13 guias
Equipe
Cal Poly, Team 24-56, Amido Spring 2011 Membro de Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,088
