Introdução
These steps will allow you to remove your CD/Optical drive with ease.
O que você precisa
Remove the 8mm Philips screw located between the hard drive and the WiFi card.
Gently pull the tray away from the laptop and the rest of the optical drive will follow.
I have tried to do this but the res of the assembly will not come out. pushing a pin in the hole release the tray but the rest of the unit will not come out
Uma outra pessoa concluiu este guia.
