Ir para o conteúdo principal
HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement
O que você precisa
  1. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Power off Device.
    • Working device while it is powered on may cause damage to laptop or electric shock.
  2. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: passo 2, imagem 1 %32
    • Flip over laptop
    • Remove the rubber foot with a Metal Spudger
  3. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: passo 3, imagem 1 %32
    • Remove the screws from the bottom of the laptop using a Phillips 00 Screwdriver.
    • 5 Phillips 2.4 x 5.7 mm screws.
    • 5 Phillips 2.0 x 5.0 mm screws.
    • Make sure to keep different screw types separated.
  4. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: passo 4, imagem 1 %32 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: passo 4, imagem 2 %32 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: passo 4, imagem 3 %32
    • Flip the laptop over to screen and keyboard side.
    • Using a Metal Spudger pop open keyboard from base of laptop.
    • Be cautious of three wires on the inside of the keyboard connecting it to the motherboard.
  5. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: passo 5, imagem 1 %32 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: passo 5, imagem 2 %32
    • Disconnect the three connected cable ribbons connected to the motherboard by gently pulling them out of their connectors.
  6. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: passo 6, imagem 1 %32 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: passo 6, imagem 2 %32
    • After ribbon cables have been disconnected, carefully lift up keyboard to disconnect from base of laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
what if it is just one key that isnt working. my enter key doesn’t work and it’s very frustrating
k.kolish2493 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 16
Duração total: 695
