Ir para o conteúdo principal
HP Pavilion x360 m3-u103dx Fan Replacement
O que você precisa
  1. HP Pavilion x360 m3-u103dx Fan Replacement, Fan: passo 1, imagem 1 %32
    • Power off device.
    • Flip laptop over.
  2. HP Pavilion x360 m3-u103dx Fan Replacement: passo 2, imagem 1 %32 HP Pavilion x360 m3-u103dx Fan Replacement: passo 2, imagem 2 %32
    • Remove the rubber foot with a Metal spudger
    • Remove 5 Phillip 2.4 x 5.7mm screws using a PH0 Phillips head screwdriver.
    • Remove 5 Phillips 2.8 x 5.0mm screws using a PH0 Phillips head screwdriver.
  3. HP Pavilion x360 m3-u103dx Fan Replacement: passo 3, imagem 1 %32 HP Pavilion x360 m3-u103dx Fan Replacement: passo 3, imagem 2 %32 HP Pavilion x360 m3-u103dx Fan Replacement: passo 3, imagem 3 %32
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Gently lift keyboard on the mouse pad side. Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  4. HP Pavilion x360 m3-u103dx Fan Replacement: passo 4, imagem 1 %32
    • Remove eleven 2.0 x 4.6mm screws using the Phillips 00 Screwdriver
  5. HP Pavilion x360 m3-u103dx Fan Replacement: passo 5, imagem 1 %32 HP Pavilion x360 m3-u103dx Fan Replacement: passo 5, imagem 2 %32 HP Pavilion x360 m3-u103dx Fan Replacement: passo 5, imagem 3 %32
    • Remove the motherboard gently from the base of the laptop.
    • Disconnect the fastened cables from the motherboard by carefully pushing the cable's plastic edges using the metal Spudger.
  6. HP Pavilion x360 m3-u103dx Fan Replacement: passo 6, imagem 1 %32 HP Pavilion x360 m3-u103dx Fan Replacement: passo 6, imagem 2 %32
    • Using the Phillips 00 Screw Driver. remove 4 screws from the heat sink.
    • Remove any adhesive tape. Detach the fan/heat sink.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 1,327
