Peças
Nenhum componente especificado.
  1. Power off device.
    • Power off device.
    • Flip the laptop over.
    • Working on your device while its powered on may cause damage to your device.
  2. Remove rubber foot closest to computer hinge with a Metal Spudger.
    • Remove rubber foot closest to computer hinge with a Metal Spudger.
  3. Remove all screws from base using a Phillips head 00 screwdriver.
    • Remove all screws from base using a Phillips head 00 screwdriver.
    • 5 Phillip 2.4 x 5.7 mm screws.
    • 5 Phillips 2.8 x 5.0 mm screws.
  4. Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard. Be careful not to pull or disconnect ribbon cables first. Be careful not to pull or disconnect ribbon cables first.
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Be careful not to pull or disconnect ribbon cables first.
  5. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  6. Gently lift the keyboard on the mouse pad side, but do not remove. The keyboard is still connected by three ribbon cables.
    • Gently lift the keyboard on the mouse pad side, but do not remove.
    • The keyboard is still connected by three ribbon cables.
    • Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  7. Use a Phillips #00 screwdriver to remove six screws around the battery.
    • Use a Phillips #00 screwdriver to remove six screws around the battery.
    • 6 Phillips 2.0 x 4.6 mm screws.
  8. Gently lift the battery up and away from the casing. Carefully remove the battery from its connecting port.
    • Gently lift the battery up and away from the casing.
    • Carefully remove the battery from its connecting port.
  9. Pull the charge port connector out gently with the tweezers.
    • Pull the charge port connector out gently with the tweezers.
  10. The charge port connector will be released from the motherboard.
    • The charge port connector will be released from the motherboard.
  11. The charge port is now ready to be replaced with a new piece.
    • The charge port is now ready to be replaced with a new piece.
  12. Once you have replaced the new charge port , insert into the  motherboard
    • Once you have replaced the new charge port , insert into the motherboard
Conclusão
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 37
All Time: 142
