Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
In this guide you will be required to remove the keyboard from the device in order to remove the battery. You will need to use a iFixit Pro Tech Toolkit.
This task requires patience and attention to detail.
Peças
Nenhum componente especificado.
  1. Power off device.
    • Power off device.
    • Flip the laptop over.
    • Working on your device while its powered on may cause damage to your device.
  2. Remove rubber foot closest to computer hinge with a Metal Spudger.
    • Remove rubber foot closest to computer hinge with a Metal Spudger.
  3. Remove all screws from base using a Phillips head 00 screwdriver.
    • Remove all screws from base using a Phillips head 00 screwdriver.
    • 5 Phillip 2.4 x 5.7 mm screws.
    • 5 Phillips 2.8 x 5.0 mm screws.
  4. Telas LCD de reposição iPhone (com ferramentas)
    A opção econômica, coberta por nossa garantia vitalícia.
    Confira os kits
    Reduza os custos de reparo, não a qualidade.
    Confira os kits
  5. Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard. Be careful not to pull or disconnect ribbon cables first. Be careful not to pull or disconnect ribbon cables first.
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Be careful not to pull or disconnect ribbon cables first.
  6. Gently lift the keyboard on the mouse pad side, but do not remove. The keyboard is still connected by three ribbon cables.
    • Gently lift the keyboard on the mouse pad side, but do not remove.
    • The keyboard is still connected by three ribbon cables.
    • Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  7. Use a Phillips #00 screwdriver to remove six screws around the battery.
    • Use a Phillips #00 screwdriver to remove six screws around the battery.
    • 6 Phillips 2.0 x 4.6 mm screws.
  8. Gently lift the battery up and away from the casing. Carefully remove the battery from its connecting port.
    • Gently lift the battery up and away from the casing.
    • Carefully remove the battery from its connecting port.
Conclusão
Meaghan Hyatt
Membro desde: 17-01-2019
277 Reputação
2 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 38
Últimos 30 dias: 159
Duração total: 973
