Ir para o conteúdo principal
HP Pavilion x360 m3-u101dx Hard Drive Replacement
O que você precisa
  1. HP Pavilion x360 m3-u101dx Hard Drive Replacement, Keyboard Panel: passo 1, imagem 1 %32
    • Flip the laptop over so that the bottom of the laptop is facing up.
  2. HP Pavilion x360 m3-u101dx Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove five 1.4mm Phillips #1 screws from the bottom of the laptop.
  3. HP Pavilion x360 m3-u101dx Hard Drive Replacement: passo 3, imagem 1 %32 HP Pavilion x360 m3-u101dx Hard Drive Replacement: passo 3, imagem 2 %32 HP Pavilion x360 m3-u101dx Hard Drive Replacement: passo 3, imagem 3 %32
    • Remove the rubber grip using a plastic opening tool.
    • Remove five 1.7mm Phillips #1 screws.
  4. HP Pavilion x360 m3-u101dx Hard Drive Replacement: passo 4, imagem 1 %32 HP Pavilion x360 m3-u101dx Hard Drive Replacement: passo 4, imagem 2 %32 HP Pavilion x360 m3-u101dx Hard Drive Replacement: passo 4, imagem 3 %32
    • Lift open the laptop screen and flip it around so that the keyboard is facing up.
    • Insert a plastic opening tool into one of the corners to create a gap between the bottom panel and the keyboard panel.
    • Guide the plastic opening tool around the perimeter of the panel to detach all the clips that are supporting it in place.
    • Do not pull the panel off by one corner as it can cause damage to the plastic.
    • Detach the keyboard panel from the frame.
    • There are two ribbon cables attached to the keyboard and trackpad so do not pull the keyboard panel away until you disconnect these ribbons in the next step.
  5. HP Pavilion x360 m3-u101dx Hard Drive Replacement: passo 5, imagem 1 %32 HP Pavilion x360 m3-u101dx Hard Drive Replacement: passo 5, imagem 2 %32 HP Pavilion x360 m3-u101dx Hard Drive Replacement: passo 5, imagem 3 %32
    • Remove the two ribbon cables connected to the inside of the laptop by using a finger to lift up on the latches.
    • Remove the keyboard panel from the rest of the laptop.
  6. HP Pavilion x360 m3-u101dx Hard Drive Replacement, Hard Drive: passo 6, imagem 1 %32
    • Remove the four 3.7mm Phillips #1 screws holding the hard drive in place.
    • Remove the SATA cable from the motherboard.
  7. HP Pavilion x360 m3-u101dx Hard Drive Replacement: passo 7, imagem 1 %32
    • Unplug the SATA cable from the hard drive.
    • Gently remove the hard drive from the computer case.
Conclusão
Tyler Padutsch
Membro desde: 01/22/20
178 Reputação
Autoria de 2 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 34
Ao todo: 1,761
