Ir para o conteúdo principal
HP Pavilion x360 m3-u001dx Hard Drive Replacement
O que você precisa
  1. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Keyboard: passo 1, imagem 1 %32
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 2, imagem 1 %32 HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 2, imagem 2 %32
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 3, imagem 1 %32
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
    “5 Phillips 2.4 x 5.7 mm screws”
    “5 Phillips 2.0 x 5.0 mm screws”
    I think the color for the sizes are mixed up, because the one near the screen bending part are the bigger ones, yet it says they are the “2.0 x 5.0 mm” but they are the bigger ones.
    If I’m wrong, tell me because I’m not sure if thats the ways they’re named because I’m not an expert at screw sizes.
    SomeRandomChild - Responder
  4. HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 4, imagem 1 %32
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 5, imagem 1 %32 HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 5, imagem 2 %32
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 6, imagem 1 %32
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 7, imagem 1 %32
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 8, imagem 1 %32
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Battery: passo 9, imagem 1 %32
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 10, imagem 1 %32
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Hard Drive: passo 11, imagem 1 %32
    • Disconnect the ribbon cables attaching the hard drive to the system board (motherboard).
    • Use the purple plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  12. HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 12, imagem 1 %32 HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 12, imagem 2 %32
    • Using the Phillips00 Screw Driver, remove 4 Phillips 2.0 x 4.6 mm screws around the perimeter of the hard drive.
  13. HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 13, imagem 1 %32
    • Using the tab provided, lift and remove the hard drive out of the laptop base.
  14. HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 14, imagem 1 %32 HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 14, imagem 2 %32
    • Using the Phillips00 Screw Driver, remove 4 Phillips 3.0 x 3.7 mm screws on exterior mounting bracket.
    • There are 2 Phillips screws on each side of the hard drive bracket.
  15. HP Pavilion x360 m3-u001dx Hard Drive Replacement: passo 15, imagem 1 %32
    • Remove the mounting bracket.
Conclusão
Follow these instructions in reverse order to reassemble your device.
9 outras pessoas executaram este guia.
Subhleen
Membro desde: 02/01/17
1.268 Reputação
Autoria de 5 guias
Equipe
UW Tacoma, Team 1-6, Rose Winter 2017 Membro de UW Tacoma, Team 1-6, Rose Winter 2017
UWT-ROSE-W17S1G6
Membros da 4
Autoria de 8 guias
8 comentários
Awesome. Thanks. This helped me a lot.
Gouse Khan - Responder
Can anyone tell me the model number of the hdd ribbon cable please :)
James Harris - Responder
I need to replace the data ribbon as well.
KurwynK -
Found it. part# 856011–001
KurwynK - Responder
My HP Pavilion X360 M3-u00ldx is not recognizing my brand new Samsung 860 Evo 500GB ssd. Upon start up I get  3F0 error which states there is no hard drive. When I boot to a Windows 10 disc it also doesn't recognize it.
Any suggestions on how it can be recognized is appreciated.
Thank you for looking.
downdog89 - Responder
I have the same issue, please let me know if you fix it.
Owen Schilling -
Very helpful, thank you! My model (m1-u001dx) had an extra screw under the long rubber strip in the middle in case that helps someone else.
Pat Paulson - Responder
I have a x360 m3 from 2018 that looks identical to this one on the outside, but when I opened it up it had empty space where the SATA drive would have been. So be warned to disassemble before you buy your replacement part. In this case, the attachment point on the motherboard for the ribbon cable was bare, so even if I could have found the HD "caddy" there wouldn't have been a place to plug it in. My only option was to buy a new m.2 board.
alan e robinson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 82
Duração total: 22,233
