Introdução
The battery is defective if the power is draining quickly after a full charge, or doesn't receive charge at all. Then use this guide.
Ferramentas
Peças
Nenhum componente especificado.
Shut down the computer.
Disconnect the power and all external devices connected to the computer.
Remove all of the screws located on the bottom of the laptop:
5 Phillips 2.4 x 5.7 mm screws
5 Phillips 2.0 x 5.0 mm screws
“5 Phillips 2.4 x 5.7 mm screws”
“5 Phillips 2.0 x 5.0 mm screws”
I think the color for the sizes are mixed up, because the one near the screen bending part are the bigger ones, yet it says they are the “2.0 x 5.0 mm” but they are the bigger ones.
If I’m wrong, tell me because I’m not sure if thats the ways they’re named because I’m not an expert at screw sizes.
Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
Follow these instructions in reverse order to reassemble your device.
6 outras pessoas concluíram este guia.
Um comentário
Thanks for this easy step by step guide. The pictures were incredibly helpful!
