Ir para o conteúdo principal
HP Pavilion x360 m3-u001dx Battery Replacement
O que você precisa
  1. HP Pavilion x360 m3-u001dx Battery Replacement, Keyboard: passo 1, imagem 1 %32
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx Battery Replacement: passo 2, imagem 1 %32 HP Pavilion x360 m3-u001dx Battery Replacement: passo 2, imagem 2 %32
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx Battery Replacement: passo 3, imagem 1 %32
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u001dx Battery Replacement: passo 4, imagem 1 %32
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx Battery Replacement: passo 5, imagem 1 %32 HP Pavilion x360 m3-u001dx Battery Replacement: passo 5, imagem 2 %32
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx Battery Replacement: passo 6, imagem 1 %32
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx Battery Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Heavy-Duty Spudger
    Comprar
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx Battery Replacement: passo 8, imagem 1 %32
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx Battery Replacement, Battery: passo 9, imagem 1 %32
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx Battery Replacement: passo 10, imagem 1 %32
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
Conclusão
Follow these instructions in reverse order to reassemble your device.
7 outras pessoas executaram este guia.
Subhleen
Membro desde: 02/01/17
1.268 Reputação
Autoria de 5 guias
Equipe
UW Tacoma, Team 1-6, Rose Winter 2017 Membro de UW Tacoma, Team 1-6, Rose Winter 2017
UWT-ROSE-W17S1G6
Membros da 4
Autoria de 8 guias
2 comentários
Thanks for this easy step by step guide. The pictures were incredibly helpful!
azbeasleys - Responder
I replaced the battery now the screen doesn't turn on. I plugged it into an external monitor and the computer works fine and even the touch aspect of the screen works, but it stays black. Did i accidentally disconnect something?
G Bates - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 7,308
