Ir para o conteúdo principal
HP Pavilion x360 m1-u001dx Keyboard Replacement
O que você precisa
  1. HP Pavilion x360 m1-u001dx Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Power off your device and disconnect all external devices connected to the laptop.
    • Working on your device while it is powered on may cause damage to the laptop or result in electric shock.
  2. HP Pavilion x360 m1-u001dx Keyboard Replacement: passo 2, imagem 1 %32
    • Flip the laptop over and remove the rubber foot with a Metal Spudger.
  3. HP Pavilion x360 m1-u001dx Keyboard Replacement: passo 3, imagem 1 %32
    • Remove the screws from the bottom of the laptop with a Phillips 00 Screwdriver.
    • 5 Phillips 2.4 x 5.7 mm screws
    • 7 Phillips 2.0 x 5.0 mm screws
    • Keep the different sized screws separate for future replacement.
  4. HP Pavilion x360 m1-u001dx Keyboard Replacement: passo 4, imagem 1 %32 HP Pavilion x360 m1-u001dx Keyboard Replacement: passo 4, imagem 2 %32 HP Pavilion x360 m1-u001dx Keyboard Replacement: passo 4, imagem 3 %32
    • Flip the laptop back over and open it; the keyboard should be facing upwards.
    • Using the Plastic Opening Tool, separate the keyboard from the base of the laptop.
    • The keyboard is connected to the motherboard with cable ribbons, so be very gentle and careful when lifting the keyboard.
  5. HP Pavilion x360 m1-u001dx Keyboard Replacement: passo 5, imagem 1 %32 HP Pavilion x360 m1-u001dx Keyboard Replacement: passo 5, imagem 2 %32 HP Pavilion x360 m1-u001dx Keyboard Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Heavy-Duty Spudger
    Comprar
    • Raising the keyboard, disconnect the first of two cable ribbons with the Heavy-Duty Spudger.
    • Gently flip up the white plastic lock connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
  6. HP Pavilion x360 m1-u001dx Keyboard Replacement: passo 6, imagem 1 %32 HP Pavilion x360 m1-u001dx Keyboard Replacement: passo 6, imagem 2 %32
    • Gently flip up the white plastic lock connecting the second ribbon cable to the motherboard with the Heavy-Duty Spudger.
    • Use the blue purple tab on the ribbon cable to disconnect the ribbon cable from the lock.
  7. HP Pavilion x360 m1-u001dx Keyboard Replacement: passo 7, imagem 1 %32 HP Pavilion x360 m1-u001dx Keyboard Replacement: passo 7, imagem 2 %32
    • After the ribbon cables are disconnected, gently lift up the keyboard to disconnect it from the base of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Katie
Membro desde: 09/21/17
549 Reputação
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 1,723
