Ir para o conteúdo principal
HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement
O que você precisa
  1. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement, RAM: passo 1, imagem 1 %32 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement, RAM: passo 1, imagem 2 %32 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement, RAM: passo 1, imagem 3 %32
    • Turn off the device and set it upside down. Orient the hinges away from you.
    • Wedge the opening pick under the grip. Lift the end of the grip.
    • Pull the grip off all the way. Repeat for the second grip.
  2. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: passo 2, imagem 1 %32 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: passo 2, imagem 2 %32 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: passo 2, imagem 3 %32
    • Use PH0 to remove the 3mm screw from the center bottom.
    • Use PH1 to remove the 6mm screw from all four corners.
  3. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: passo 3, imagem 1 %32 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: passo 3, imagem 2 %32 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: passo 3, imagem 3 %32
    • Use the opening pick to separate the back panel from the device.
    • Begin near the hinge and carefully follow the perimeter until you have taken the pick around all four sides.
    • The back panel will come loose once the pick has been around the whole edge of the device.
    • Lift the panel off.
  4. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: passo 4, imagem 1 %32 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: passo 4, imagem 2 %32
    • Pinch and lift the black and gray plate labeled with "WLAN."
  5. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: passo 5, imagem 1 %32
    • Use the spudger to unhook the locks on each side of the green RAM stick.
    • The locks will be unhooked by pushing them gently away from the RAM sticks.
  6. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: passo 6, imagem 1 %32 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: passo 6, imagem 2 %32
    • Gently pull the RAM stick up and out to remove.
    • Repeat the previous two steps to remove the second RAM strip.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 323
