Ir para o conteúdo principal
HP Pavilion x360 15t-br000 Speakers Replacement
O que você precisa
  1. HP Pavilion x360 15t-br000 Speakers Replacement, Keyboard Panel: passo 1, imagem 1 %32 HP Pavilion x360 15t-br000 Speakers Replacement, Keyboard Panel: passo 1, imagem 2 %32 HP Pavilion x360 15t-br000 Speakers Replacement, Keyboard Panel: passo 1, imagem 3 %32
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Speakers Replacement: passo 2, imagem 1 %32 HP Pavilion x360 15t-br000 Speakers Replacement: passo 2, imagem 2 %32 HP Pavilion x360 15t-br000 Speakers Replacement: passo 2, imagem 3 %32
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Speakers Replacement, Battery: passo 3, imagem 1 %32
    • Disconnect the battery cable from the device.
  4. HP Pavilion x360 15t-br000 Speakers Replacement: passo 4, imagem 1 %32 HP Pavilion x360 15t-br000 Speakers Replacement: passo 4, imagem 2 %32
    • Remove the seven Phillips #0 4.5 mm screws.
    • Remove the battery from the device.
  5. HP Pavilion x360 15t-br000 Speakers Replacement, Speakers: passo 5, imagem 1 %32 HP Pavilion x360 15t-br000 Speakers Replacement, Speakers: passo 5, imagem 2 %32 HP Pavilion x360 15t-br000 Speakers Replacement, Speakers: passo 5, imagem 3 %32
    • Disconnect the white speaker cable connection from the motherboard.
    • Unscrew the four 3 mm screws mounting the speakers to the laptop using a Phillips #0 screwdriver.
    • Remove the speakers from the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 121
