Ir para o conteúdo principal
HP Pavilion x360 15t-br000 Keyboard Replacement
O que você precisa
  1. HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard Panel: passo 1, imagem 1 %32 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard Panel: passo 1, imagem 2 %32 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard Panel: passo 1, imagem 3 %32
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Keyboard Replacement: passo 2, imagem 1 %32 HP Pavilion x360 15t-br000 Keyboard Replacement: passo 2, imagem 2 %32 HP Pavilion x360 15t-br000 Keyboard Replacement: passo 2, imagem 3 %32
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard: passo 3, imagem 2 %32 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard: passo 3, imagem 3 %32
    • Remove the two tapes of connected with the track board and the keyboard panel.
    • Remove the seven 2mm screws using the Phillips #0 screwdriver.
    • Remove the trackpad from the device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 502
