Ir para o conteúdo principal
HP Pavilion x360 14m-cd0005dx Motherboard Replacement
O que você precisa
  1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 2, imagem 1 %32
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 3, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 3, imagem 2 %32
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 4, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 4, imagem 2 %32
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 5, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 5, imagem 2 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 5, imagem 3 %32
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: passo 6, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: passo 6, imagem 2 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: passo 6, imagem 3 %32
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 7, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 7, imagem 2 %32
    • Carefully lift from the base and remove the battery.
  8. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Heat Sink and Fan: passo 8, imagem 1 %32
    • Remove the tape that secures the fan to the computer.
  9. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 9, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Find the fan cable
    • Use the Reverse Tweezers to unplug the fan cable
  10. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 10, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 10, imagem 2 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 10, imagem 3 %32
    • Remove all screws securing the fan to the device:
    • Two Phillips #00 4.5mm screws
    • Four Phillips #00 4.5mm screws
  11. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 11, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 11, imagem 2 %32
    • Lift and remove the fan and heat sink from the device.
    • When removing the fan, there will be an adhesive strip attached to the bottom. There may be some resistance as the device is being removed. Use a spudger to hold the adhesive down during removal.
  12. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Motherboard: passo 12, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Motherboard: passo 12, imagem 2 %32
    • Remove all screws securing the motherboard to the device:
    • Ten Phillips #0 4.5mm screws
  13. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 13, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 13, imagem 2 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 13, imagem 3 %32
    Comprar
    • Use the Reverse Tweezers to disconnect the speaker cables from the motherboard.
  14. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 14, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 14, imagem 2 %32
    • Slide out the ribbon wire from the motherboard
  15. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 15, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: passo 15, imagem 2 %32
    • Gently lift the motherboard out of the device
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 683
