Ir para o conteúdo principal
HP Pavilion x360 14m-cd0005dx Battery Replacement
O que você precisa
  1. HP Pavilion x360 14m-cd0005dx Battery Replacement, Back Cover: passo 1, imagem 1 %32
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 2, imagem 1 %32
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 3, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 3, imagem 2 %32
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 4, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 4, imagem 2 %32
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 5, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 5, imagem 2 %32 HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 5, imagem 3 %32
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: passo 6, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: passo 6, imagem 2 %32 HP Pavilion x360 14m-cd0005dx Battery Replacement, Battery: passo 6, imagem 3 %32
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 7, imagem 1 %32 HP Pavilion x360 14m-cd0005dx Battery Replacement: passo 7, imagem 2 %32
    • Carefully lift from the base and remove the battery.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 1,442
