Ir para o conteúdo principal
HP Pavilion x360 14m-ba011dx Touchpad Replacement
O que você precisa
  1. HP Pavilion x360 14m-ba011dx Touchpad Replacement, Touchpad: passo 1, imagem 1 %32 HP Pavilion x360 14m-ba011dx Touchpad Replacement, Touchpad: passo 1, imagem 2 %32
    • Remove the top left and right rubber pads closest to the hinge of the screen using a plastic spudger to locate the screws underneath. ​
    • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:
    • Remove two 7.5 mm screws.
    • Remove three 5 mm screws.
    • Remove one 6.5 mm screw.
  2. HP Pavilion x360 14m-ba011dx Touchpad Replacement: passo 2, imagem 1 %32
    • Push into the two screw holes located under the rubber pads with the screwdriver to pop the keyboard out slightly.
    • Do this with the screen open so that you do not damage the screen.
    • Do not remove the keyboard all the way.
  3. HP Pavilion x360 14m-ba011dx Touchpad Replacement: passo 3, imagem 1 %32 HP Pavilion x360 14m-ba011dx Touchpad Replacement: passo 3, imagem 2 %32
    • Separate the keyboard from the rest of the device using a metal spudger around edges.
    • Pull up gently until you can see the cables attaching the keyboard to the motherboard.
    • Flip the small white clasps that hold the three cables to the motherboard open and unplug the cables.
  4. HP Pavilion x360 14m-ba011dx Touchpad Replacement: passo 4, imagem 1 %32 HP Pavilion x360 14m-ba011dx Touchpad Replacement: passo 4, imagem 2 %32
    • Flip the now removed keyboard over to expose the bottom side.
    • Unclasp the cable that connects the touchpad to the keyboard.
    • You can remove this cable the same way you removed the previous cables.
    • Remove the six 2.3 mm screws that attach the touch pad using a Phillips #00 Screwdriver.
  5. HP Pavilion x360 14m-ba011dx Touchpad Replacement: passo 5, imagem 1 %32 HP Pavilion x360 14m-ba011dx Touchpad Replacement: passo 5, imagem 2 %32
    • Pull off the metal piece holding the touchpad in place.
    • Remove the touchpad from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 16
Duração total: 1,555
