Introdução
Before using this guide, make sure to review the troubleshooting page for the HP Pavilion x360 14m-ba011dx. The motherboard may not actually need to be replaced depending on the problem, which is why it is good to trouble shoot first.
With this guide, the user will be able to remove and replace the motherboard of the HP Pavilion x360 14m-ba011dx laptop. The model number for this device is 1KT47UA. The motherboard is one of the most essential parts of your computer because it controls many different components of the laptop such as memory and the connectors for inputs and outputs. The motherboard may need to be replaced if your computer is having any hardware issues.
O que você precisa
Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:
Two 7.5 mm screws.
Three 5 mm screws.
One 6.5 mm screw.
