Ir para o conteúdo principal
HP Pavilion x360 14-ba253cl Keyboard Replacement
O que você precisa
  1. HP Pavilion x360 14-ba253cl Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Keyboard Replacement: passo 2, imagem 1 %32
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Keyboard Replacement: passo 3, imagem 1 %32
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Keyboard Replacement: passo 4, imagem 1 %32
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Keyboard Replacement: passo 5, imagem 1 %32
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Kristen Gismondi
Membro desde: 11/12/14
82.723 Reputação
Autoria de 202 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.442 guias
Um comentário
Kristen, How is the keyboard mounted to the top panel?
Larry Levy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 88
Duração total: 7,024
