Ir para o conteúdo principal
HP Pavilion x360 14-ba253cl Display Replacement
O que você precisa
  1. HP Pavilion x360 14-ba253cl Display Replacement, Display: passo 1, imagem 1 %32 HP Pavilion x360 14-ba253cl Display Replacement, Display: passo 1, imagem 2 %32
    • Insert an opening pick between the screen and top case to separate it from the laptop.
  2. HP Pavilion x360 14-ba253cl Display Replacement: passo 2, imagem 1 %32 HP Pavilion x360 14-ba253cl Display Replacement: passo 2, imagem 2 %32 HP Pavilion x360 14-ba253cl Display Replacement: passo 2, imagem 3 %32
    • Once the screen is pryed away from the laptop, lay the screen face down onto the keyboard.
  3. HP Pavilion x360 14-ba253cl Display Replacement: passo 3, imagem 1 %32 HP Pavilion x360 14-ba253cl Display Replacement: passo 3, imagem 2 %32 HP Pavilion x360 14-ba253cl Display Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove any tape or wires that connect the screen and laptop together using tweezers.
  4. HP Pavilion x360 14-ba253cl Display Replacement: passo 4, imagem 1 %32
    • Remove the display from the laptop.
Conclusão
5 outras pessoas executaram este guia.
2 comentários
If you came here looking for a lcd back cover replacement don't bother. You have to damage the new part to install. Horrible design.
Ender - Responder
This didn't help at all... You took as little pics as possible and didn't show the reinstall.
Cameron Coppoletta - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 70
Duração total: 6,069
