Ir para o conteúdo principal
HP Pavilion x360 14-ba253cl Battery Replacement
O que você precisa
  1. HP Pavilion x360 14-ba253cl Battery Replacement, Keyboard: passo 1, imagem 1 %32
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Battery Replacement: passo 2, imagem 1 %32
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Battery Replacement: passo 3, imagem 1 %32
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Battery Replacement: passo 4, imagem 1 %32
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Battery Replacement: passo 5, imagem 1 %32
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
  6. HP Pavilion x360 14-ba253cl Battery Replacement, Battery: passo 6, imagem 1 %32
    • Remove six 3mm Phillips #00 screws around the perimeter of the battery.
  7. HP Pavilion x360 14-ba253cl Battery Replacement: passo 7, imagem 1 %32
    • Carefully lift the battery starting from the lower right corner and disconnect it from the system board.
Conclusão
5 outras pessoas executaram este guia.
Um comentário
Thanks, it was useful
Oleg - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 28
Últimos 30 dias: 97
Duração total: 8,417
