Ir para o conteúdo principal
HP Pavilion x360 11m-ad013dx Speaker Replacement
O que você precisa
  1. HP Pavilion x360 11m-ad013dx Speaker Replacement, Keyboard: passo 1, imagem 1 %32
    • Lay the HP Pavilion top-down with the front edge facing towards you.
  2. HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 2, imagem 1 %32
    • Remove the three 4.8mm Phillips #0 screws from the front side.
  3. HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 3, imagem 1 %32 HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 3, imagem 2 %32
    • Using a plastic spudger, remove the grey silicon strip closest to the back-side.
  4. HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 4, imagem 1 %32
    • Remove the three 5.7mm Phillips #1 screws.
  5. HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 5, imagem 1 %32 HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 5, imagem 2 %32
    • Open the HP Pavilion so that the screen is showing. Then tilt it down so that the screen is on its back, facing up.
    • Using a spudger, pry off the black keyboard panel.
    • This step requires force to unclasp the latches keeping the keyboard in place.
  6. HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 6, imagem 1 %32 HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 6, imagem 2 %32
    • Using your fingernail, disconnect the zero insertion force (ZIF) keyboard connector cable by flipping up the small locking flap.
    • You may disconnect the other end of the cable, for ease of access to other parts. Keep in mind that the end labeled MB connects to the motherboard.
  7. HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 7, imagem 1 %32 HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 7, imagem 2 %32
    • Using your fingernail, disconnect the zero insertion force (ZIF) connector for the touch pad cable by flipping up the small locking flap.
  8. HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 8, imagem 1 %32
    • Remove the keyboard.
  9. HP Pavilion x360 11m-ad013dx Speaker Replacement, Battery: passo 9, imagem 1 %32
    • Remove the five 4.6mm Phillips #1 screws located around the battery.
  10. HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 10, imagem 1 %32 HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 10, imagem 2 %32
    • Using a spudger for assistance, lift up the right edge of the battery.
    • Remove the battery.
  11. HP Pavilion x360 11m-ad013dx Speaker Replacement, Speaker: passo 11, imagem 1 %32 HP Pavilion x360 11m-ad013dx Speaker Replacement, Speaker: passo 11, imagem 2 %32
    • Using your fingernail, disconnect the ZIF (zero insertion force) hard drive cable by flipping up the small locking flap.
  12. HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 12, imagem 1 %32 HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 12, imagem 2 %32
    • With your fingernails, disconnect the speaker cable from the motherboard by pulling back on the connector.
    • Do not directly pull on the wires, as this can damage the connector.
  13. HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 13, imagem 1 %32 HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 13, imagem 2 %32
    • Lift the speaker cable from its retention chamber.
  14. HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 14, imagem 1 %32
    • Remove the four 6.2mm Phillips #1 screws around the speakers.
  15. HP Pavilion x360 11m-ad013dx Speaker Replacement: passo 15, imagem 1 %32
    • Remove the speakers.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 251
