Introdução
This guide demonstrates how to replace the touchpad on a HP Pavilion x360 11-p110nr. The entire process is fairly quick and easy, and with a bit of care, it can be completed safely at home.
Caution: Anytime you are working with batteries or power, be sure to take care around electricity and always unplug the battery before you attempt to replace any part of the laptop.
O que você precisa
Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
Once the screws are removed, carefully take the bottom plate off.
