Introdução
This guide shows you how to replace the charging port in your HP Pavilion x360 11-p110nr laptop. This repair may be necessary whenever the laptop is not able to charge, hold a charge, or power on.
Before committing to replacing the charging port, it is worth checking that the charger being used works. This can be accomplished by trying a different charger on the laptop, or trying the charger on a different laptop.
Using only a screwdriver and the replacement part, the entire process is fairly quick and easy, and with a bit of care it can be completed safely at home.
Caution: Anytime you are working with batteries or power, be sure to take care around the electricity and always unplug the battery before you attempt to replace the port.
O que você precisa
Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
Carefully take the bottom cover off.
