Ir para o conteúdo principal
HP Pavilion x360 11-p110nr Battery Replacement
O que você precisa
  1. HP Pavilion x360 11-p110nr Battery Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion x360 11-p110nr Battery Replacement, Battery: passo 1, imagem 2 %32
    • First, unplug the power cord from the power outlet and disconnect the charger.
    • Flip over the laptop.
    • Unscrew the back cover using the Phillips #0 screwdriver.
    • Deattach the cover carefully and do not remove the cover completely as there is a safety plastic that needs to be removed first.
    • Remove the blue safety plastic in an orthogonal motion from where it is inserted carefully.
  2. HP Pavilion x360 11-p110nr Battery Replacement: passo 2, imagem 1 %32 HP Pavilion x360 11-p110nr Battery Replacement: passo 2, imagem 2 %32
    • Remove the five 1 mm screws connecting the battery to the base of the computer using a Phillips #0 screwdriver.
  3. HP Pavilion x360 11-p110nr Battery Replacement: passo 3, imagem 1 %32
    • Carefully disconnect the three connectors by pulling them away from the slot.
    • If they seem hard to pull, try to wiggle them loose to making it easier to pull.
    • Pull out the battery after everything is disconnected.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 589
