Ir para o conteúdo principal
HP Pavilion x360 11-p110nr Hard Drive Replacement
O que você precisa
  1. HP Pavilion x360 11-p110nr  Hard Drive  Replacement, Hard Drive: passo 1, imagem 1 %32
    • Make sure the laptop is turned off, and the power cable is removed.
    • Leaving the laptop turned on can cause damage to the hardware and any stored data.
  2. HP Pavilion x360 11-p110nr  Hard Drive  Replacement: passo 2, imagem 1 %32
    • Turn the laptop over to access the backside of the computer.
    • Identify and confirm that the laptop is an HP Pavilion x360 11-p110nr.
    • Remove the nine screws from the back panel using a Phillips #0 screwdriver.
  3. HP Pavilion x360 11-p110nr  Hard Drive  Replacement: passo 3, imagem 1 %32
    • Remove the four screws holding in the hard drive compartment using a Phillips #0 screwdriver.
    • Pull the hard drive up and out to remove it from the compartment.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 1,978
