Ir para o conteúdo principal
HP Pavilion x2 10-n113dx Touch Pad Replacement
O que você precisa
  1. HP Pavilion x2 10-n113dx Touch Pad Replacement, Touch Pad: passo 1, imagem 1 %32 HP Pavilion x2 10-n113dx Touch Pad Replacement, Touch Pad: passo 1, imagem 2 %32
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Loosen the adhesive under the gray plastic bar using a heat pad or a heat gun.
    • Remove the gray plastic bar after 5 minutes of light heat with tweezers by pulling up.
  3. HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 3, imagem 1 %32
    • Remove the 4 screws with a Phillips #0 screwdriver.
    • These 4 screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 4, imagem 1 %32 HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 4, imagem 2 %32
    • Remove the rubber stoppers at the top left and right with tweezers.
    • Remove the screws at the top and right with at Phillips #0 screwdriver.
    • These two screws have a diameter of 5.3 mm and a height of 4.3 mm.
  5. HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 5, imagem 1 %32 HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 5, imagem 2 %32 HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 5, imagem 3 %32
    • Pry open the back case with a metal spudger.
    • Then pry open the back layer with the metal spudger.
  6. HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 6, imagem 1 %32 HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 6, imagem 2 %32
    • Fully take off the back panel by lifting up the panel.
  7. HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 7, imagem 1 %32 HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 7, imagem 2 %32
    • Pop open the ribbon cable piece on the touch pad with the blue plastic spudger.
    • Remove the ribbon cable with tweezers by pulling it out.
  8. HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 8, imagem 1 %32 HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 8, imagem 2 %32
    • Remove 4 screws with at Phillips #0 screwdriver. All 4 screws have a diameter of 4.3 mm and a height of 3.7 mm.
    • Lift the tape shown with orange boxes with tweezers.
    • Remove metal bar with a blue spudger.
  9. HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 9, imagem 1 %32 HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 9, imagem 2 %32 HP Pavilion x2 10-n113dx Touch Pad Replacement: passo 9, imagem 3 %32
    • Lift up the touch pad by the metal edge with a blue plastic spudger.
    • Remove the touch pad from the computer.
Conclusão
Cayla Skaggs
Membro desde: 04/01/19
337 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G4, Harley Spring 2019 Membro de IUPUI, Team S1-G4, Harley Spring 2019
IUPUI-HARLEY-S19S1G4
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 725
