Introdução
This guide covers the removal and replacement of the HP Pavilion x2 10-n113dx front facing camera. From opening the device to the removal of the camera circuit board. Throughout this guide we will use a PH0 driver bit, blue plastic opening tools, and a pair of tweezers.
O que você precisa
Separate the screen from the keyboard.
The keyboard and screen are held together via magnets.
Open the device and pull the screen parallel to its face.
Follow the attached ribbon cable to the circuit board of the device.
On the side of the ribbon cable, use a small plastic spudger to pop open this plastic lock and gently pull in the direction of the cable to remove.
Gently lift up on the battery connector just below the earlier removed ribbon cable to remove.
Unscrew and remove each of the four indicated screws using the Phillips #0 screwdriver.
Begin with the bottom left 4.5mm diameter screw.
Continue to the remaining three 2.0 mm diameter screws.
Once all four screws have been removed lift the battery from the device using the indicated pull tab along the top edge.
