Ir para o conteúdo principal
HP Pavilion x2 10-n113dx Mainboard Replacement
O que você precisa
  1. HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: passo 1, imagem 2 %32 HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: passo 1, imagem 3 %32
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx  Mainboard Replacement: passo 2, imagem 1 %32 HP Pavilion x2 10-n113dx  Mainboard Replacement: passo 2, imagem 2 %32
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx  Mainboard Replacement: passo 3, imagem 1 %32 HP Pavilion x2 10-n113dx  Mainboard Replacement: passo 3, imagem 2 %32 HP Pavilion x2 10-n113dx  Mainboard Replacement: passo 3, imagem 3 %32
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx  Mainboard Replacement: passo 4, imagem 1 %32 HP Pavilion x2 10-n113dx  Mainboard Replacement: passo 4, imagem 2 %32 HP Pavilion x2 10-n113dx  Mainboard Replacement: passo 4, imagem 3 %32
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx  Mainboard Replacement: passo 5, imagem 1 %32 HP Pavilion x2 10-n113dx  Mainboard Replacement: passo 5, imagem 2 %32 HP Pavilion x2 10-n113dx  Mainboard Replacement: passo 5, imagem 3 %32
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
  6. HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: passo 6, imagem 1 %32 HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: passo 6, imagem 2 %32 HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: passo 6, imagem 3 %32
    • To unscrew the mainboard use the Phillips #0 Screwdriver to remove two types of screws. Three 4.15mm head, 2.35mm in length screws and three 3.32mm head, 3.99mm in length screws
  7. HP Pavilion x2 10-n113dx  Mainboard Replacement: passo 7, imagem 1 %32 HP Pavilion x2 10-n113dx  Mainboard Replacement: passo 7, imagem 2 %32 HP Pavilion x2 10-n113dx  Mainboard Replacement: passo 7, imagem 3 %32
    • Remove mainboard.
Conclusão
4 outras pessoas executaram este guia.
David Zambrano
Membro desde: 09/28/17
822 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S13-G4, Boczar Fall 2017 Membro de USF Tampa, Team S13-G4, Boczar Fall 2017
USFT-BOCZAR-F17S13G4
Membros da 4
Autoria de 5 guias
4 comentários
Is this about the WiFi card? Because I cant see the SSD in any of your pictures.
Julian Lemmerich - Responder
So, where is the SSD? You’ve taken apart the whole logic board, but not evidence of any SSD module from your photos….
Matteo Repossi - Responder
It is not SSD drive, it is a motherboard
Da K - Responder
has anyone figured out where is the SSD (eMMC) by the way ?
Karantez Jegou - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 7,476
