Introdução
This guide provides instructions on the disassembly of the HP Pavilion tx2500 for fan replacement.
O que você precisa
Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
Disconnect the wire from the system board using the plastic opening tool.
Disconnect the wire from the optical drive using the plastic opening tool.
Gently lift the top cover from the tablet.
Uma outra pessoa concluiu este guia.
