Introdução
Did your hard drive crash? Or are you looking for more speed or capacity from a new hard drive? This guide will walk you through replacing your hard drive
Ferramentas
Peças
Nenhum componente especificado.
Unscrew one Phillips #1 screw from the back panel.
Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
Pull the black cable up and out of the back panel. This will make taking the hard drive out much easier.
To reassemble or replace your hard drive, follow these instructions in reverse order with the working drive.
4 outras pessoas concluíram este guia.
