Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Laptop cooking your lap? This guide will walk you through replacing your fan.
For help applying thermal paste, you can reference the iFixit Thermal Paste Application guide.
  1. Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. The battery is held in by a latch in the front and tabs in the back.
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
  3. Unscrew one Phillips #1 screw from the back panel.
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  4. Slide the back panel down and pull it up. Slide the back panel down and pull it up.
    • Slide the back panel down and pull it up.
  5. Static electricity can damage the components of your laptop. Make sure you are wearing an anti-static bracelet before you touch the hard drive. Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
    • Static electricity can damage the components of your laptop. Make sure you are wearing an anti-static bracelet before you touch the hard drive.
    • Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
    • Pull the black cable up and out of the back panel. This will make taking the hard drive out much easier.
  6. Gently pull up on the plastic tab attached to the hard drive. Pull the hard drive up and to the right to remove it completely from the laptop.
    • Gently pull up on the plastic tab attached to the hard drive.
    • Pull the hard drive up and to the right to remove it completely from the laptop.
  7. Use your fingers, plastic opening tools, or pliers to pull the silver brackets away from the RAM. The RAM should pop up to a 35 degree angle.
    • Use your fingers, plastic opening tools, or pliers to pull the silver brackets away from the RAM.
    • The RAM should pop up to a 35 degree angle.
  8. Gently pull the RAM straight out in the direction it currently is orientated. When inserting new RAM, place the RAM in the black housing at a 35 degree angle (it will fit loosely), then push down until it clicks into the silver brackets.
    • Gently pull the RAM straight out in the direction it currently is orientated.
    • When inserting new RAM, place the RAM in the black housing at a 35 degree angle (it will fit loosely), then push down until it clicks into the silver brackets.
    • This computer supports two sticks of RAM. To add a second stick, repeat the above step with the upper black housing. (Ensure that you have the correct size and type of RAM before trying to add it).
  9. Use a Phillips #1 screw driver to unscrew the black 4 mm Phillips #1 screw on the wireless card.
    • Use a Phillips #1 screw driver to unscrew the black 4 mm Phillips #1 screw on the wireless card.
  10. Use a plastic opening tool to lift the wireless card out of its slot. Use a plastic opening tool to lift the wireless card out of its slot.
    • Use a plastic opening tool to lift the wireless card out of its slot.
    In replacing the wireless card, I found it easiest to insert the wireless card and screw down before reattaching the wires. A strong pair of forceps or tweezers helped align the male and female connectors, which are quite small.
    jawolf3 - Responder
  11. Pull the black and white wires up and off of the wireless card. Remove the wireless card.
    • Pull the black and white wires up and off of the wireless card.
    • Remove the wireless card.
  12. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  13. Remove sixteen 7 mm Phillips #1 screws.
    • Remove sixteen 7 mm Phillips #1 screws.
  14. Unscrew the 7 mm Phillips #1 screw next to the keyboard icon.
    • Unscrew the 7 mm Phillips #1 screw next to the keyboard icon.
  15. Flip the laptop over and open the screen.
    • Flip the laptop over and open the screen.
  16. A ribbon cable is attached to the back of the keyboard. Avoid lifting or moving the keyboard more than a couple inches before you disconnect the ribbon cable or you may damage it. Carefully pry up one of the top corners of the keyboard with a prying tool. Slide the tool along the top of the keyboard to release it from the housing. Pull the top of the keyboard towards you an inch or two.
    • A ribbon cable is attached to the back of the keyboard. Avoid lifting or moving the keyboard more than a couple inches before you disconnect the ribbon cable or you may damage it.
    • Carefully pry up one of the top corners of the keyboard with a prying tool. Slide the tool along the top of the keyboard to release it from the housing. Pull the top of the keyboard towards you an inch or two.
    • The keyboard may make some cracking noises as you pry it from the casing. This is expected.
    • Pull the keyboard up and away from you, as it is held in by clips in the front. It is not yet disconnected.
  17. Gently turn keyboard over, towards you, to reveal the silver cable ribbon.
    • Gently turn keyboard over, towards you, to reveal the silver cable ribbon.
  18. Using a prying tool, flip the black clip up and to the right. Pull the silver cable out and to the left, the keyboard is now detached from the laptop. Using a prying tool, flip the black clip up and to the right. Pull the silver cable out and to the left, the keyboard is now detached from the laptop. Using a prying tool, flip the black clip up and to the right. Pull the silver cable out and to the left, the keyboard is now detached from the laptop.
    • Using a prying tool, flip the black clip up and to the right. Pull the silver cable out and to the left, the keyboard is now detached from the laptop.
  19. Unscrew the four 7 mm Phillips #1 screws on the board.
    • Unscrew the four 7 mm Phillips #1 screws on the board.
  20. Use a plastic opening tool to lift the white clip up, towards the screen. Pull the white cable with blue head, away from the clip. Pull the white cable with blue head, away from the clip.
    • Use a plastic opening tool to lift the white clip up, towards the screen.
    • Pull the white cable with blue head, away from the clip.
    Petit oubli: Il faut aussi déconnecté la nappe qui se trouve en haut à gauche.
    Jay - Responder
  21. With a plastic opening tool, pry open a side or corner of the top panel. Slide the tool around the rest of the panel to release it from the clips. If you have to use a large amount of force, you may not have removed all the necessary screws. Double check to ensure you have.
    • With a plastic opening tool, pry open a side or corner of the top panel. Slide the tool around the rest of the panel to release it from the clips.
    • If you have to use a large amount of force, you may not have removed all the necessary screws. Double check to ensure you have.
    • You should hear clips releasing from the board.
  22. Lifting the top panel too quickly or forcefully may damage the speaker cable, which is still attached underneath.
    • Lifting the top panel too quickly or forcefully may damage the speaker cable, which is still attached underneath.
    • Rotate the top panel away from you, keeping the back near the hinge of the laptop to avoid damaging the speaker cable.
  23. Using a plastic opening tool, disconnect the black speaker connector from the top right of the motherboard. Set aside the top panel until your are ready to reassemble your laptop.
    • Using a plastic opening tool, disconnect the black speaker connector from the top right of the motherboard.
    • Set aside the top panel until your are ready to reassemble your laptop.
  24. Unscrew one 7 mm Phillips #1 screw from the bottom left corner of the motherboard.
    • Unscrew one 7 mm Phillips #1 screw from the bottom left corner of the motherboard.
  25. Lift black tab for the CD drive cable in the bottom left of the motherboard. Disconnect it from the motherboard with your fingers or a plastic opening tool.
    • Lift black tab for the CD drive cable in the bottom left of the motherboard.
    • Disconnect it from the motherboard with your fingers or a plastic opening tool.
  26. Lift, with your fingers or a plastic opening tool, the large black monitor cable at the top of the left hand corner of the motherboard. Lift, with your fingers or a plastic opening tool, the large black monitor cable at the top of the left hand corner of the motherboard. Lift, with your fingers or a plastic opening tool, the large black monitor cable at the top of the left hand corner of the motherboard.
    • Lift, with your fingers or a plastic opening tool, the large black monitor cable at the top of the left hand corner of the motherboard.
  27. Use a plastic opening tool to lift the black clip up from the silver cable that's in the upper right hand corner of the computer. Pull the silver cable away from the motherboard. Pull the silver cable away from the motherboard.
    • Use a plastic opening tool to lift the black clip up from the silver cable that's in the upper right hand corner of the computer.
    • Pull the silver cable away from the motherboard.
  28. Using a small amount of force pull the black cable, below the silver cable we just removed, to the right and out of the way. Using a small amount of force pull the black cable, below the silver cable we just removed, to the right and out of the way.
    • Using a small amount of force pull the black cable, below the silver cable we just removed, to the right and out of the way.
  29. Lift the right side of the motherboard up at roughly a 45 degree angle and pull to the right to remove it.
    • Lift the right side of the motherboard up at roughly a 45 degree angle and pull to the right to remove it.
  30. Now that the motherboard is out, flip it over and begin working on the back side. Remove the red, blue, and yellow set of wires from the motherboard.
    • Now that the motherboard is out, flip it over and begin working on the back side.
    • Remove the red, blue, and yellow set of wires from the motherboard.
  31. The screws on the heat sink are held in place by screws and stoppers; they will unscrew, but will not come out of the heat sink. Be careful not to loosen them too much or you may damage the bracket on the back of the CPU. Using a Phillips #1 screw driver unscrew the four screws on the heat sink.
    • The screws on the heat sink are held in place by screws and stoppers; they will unscrew, but will not come out of the heat sink. Be careful not to loosen them too much or you may damage the bracket on the back of the CPU.
    • Using a Phillips #1 screw driver unscrew the four screws on the heat sink.
    • When tightening the screws during reassembly, tighten them in a cross pattern (start by tightening the upper left screw, then the bottom right screw, then the top right screw, and finally the bottom left screw)
    • Lift the bracket up from the motherboard.
  32. Since the fan is held on with adhesives, you will likely need a prying tool and a small amount of force to lift the fan up and off of the motherboard.
    • Since the fan is held on with adhesives, you will likely need a prying tool and a small amount of force to lift the fan up and off of the motherboard.
    • Be sure to apply a light coating of thermal paste to the CPU before you screw the heat sink back on. For help applying thermal paste, you can reference the iFixit Thermal Paste Application guide
    Where can l purchase a fan
    Sherry Ashton - Responder
    This is ridiculous !! why is there not a separate opening/doorway/removable panel so that you can get straight to the Fan ? ? because with this design you literally have to take the whole dam laptop apart…31 steps just to clean or replace a fan ?? who was the moron that came up with this retarded design ??
    I use to think the people at HP were pretty smart…Not anymore…never buying anything from HP again
    bifbarnes - Responder
    Excellent teardown. I don't need to replace the fan (yet!), but needed to get the laptop apart to find out why when I opened it yesterday, suddenly it's like the case was being pried open.
    Any idea on whether or not just the back piece of the case can be replaced?? Appears the plastic where the bracket screws into cracked apart, so there's nothing to hold the bracket in place while it pivots open & that was pushing the case apart. Going to Macgyver something for now… and heck, might as well clean it all while it's open, lol!
    Cici - Responder
Conclusão
41 outras pessoas concluíram este guia.
John Sutton
Membro desde: 24-04-2014
1.485 Reputação
8 Guias de autoria
equipe
Cal Poly, Team 11-51, Amido Spring 2014 Membro de Cal Poly, Team 11-51, Amido Spring 2014
CPSU-AMIDO-S14S11G51
4 Membros
12 Guias de autoria
I had to stop at stap 14 because i couldnt open my laptop, lifting the screen took the plastic piece around the keyboard loose. I tried to return my staps ( to still have a computer) but that plastic piece wont fit back. And i,still cant open my screen.
hendrikvandervelden - Responder
This worked well for accessing and cleaning the fan. Thanks.
alisl ahish - Responder
I just wanted to say THANK YOU for posting this instructional page. I know this took a lot of time on your part plus you done this for free to boot. It is because of people like you that make the lives of others PC life much MUCH easier!
Edward Norton - Responder
Thank you so much! It helped me a lot although I had a different g7 model.
Raimund von der Emden - Responder
Thanks!!! I was able to fix my laptop.
mdoming58182 - Responder
Thank you John! Your instructions were clear and the numbering helped me a lot in separating the various components and screws.
One point - in step 20- I disconnected a cable from a connector, roughly under where the esc key or the ~ key are. It is not mentioned in the description here. It may be that my model is different - G7-2022US.
Yaacov - Responder
Thank you so much for this tutorial! The repair shop quoted me $150 and 2 weeks to fix this, and I was able to fix this in about an hour for under $20. :) I JUST replaced the fan (heat sink was fine) so to remove it, I also had to use a teeny-tiny screwdriver (even smaller than an eyeglass repair kit size) to remove the existing screws that held the fan in place.. Other than that everything else was perfect. I have ZERO experience in repairing laptop innards, first time here, so this was exactly what I needed. It works perfectly now! While i was in there I went ahead and added 4GB RAM, so it's faster now also. THANK YOU!
sigkapgirl - Responder
Hey.. which (for replacing the fan) screwdrivers were you talking about? Phillips #1 Screwdriver doesn't work? Did you need something else?
Aditya Putatunda -
Thank you!! Absolutely perfect! thanks for taking the time to post!
bergahoo - Responder
Very Very nice layed out instruction guide. My laptop fan stopped working after spraying it with compressed air so i had to take it apart but had no idea where to start and after following the simple instruction guide i managed to find a very large piece of lint the size of a nickel lodged inside one of the internal parts of the fan which caused it to stop working. Without this guide i would not have been able to do that,
Thank you again for the very easy completely layed out instructions, very simple to follow.
saschaheinzel - Responder
What a bad design. This process makes me want to google the price of a new laptop….lol
Thanks
James Lawson - Responder
Thanks was able to fix my keyboard and did a thermalpaste swap :) extremly helpful
Marten M - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 23
Últimos 7 dias: 89
Últimos 30 dias: 270
Duração total: 36,900
