Ir para o conteúdo principal
HP Pavilion g7-1368dx Hard Drive Replacement
O que você precisa
  1. HP Pavilion g7-1368dx  Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device over so that the lower case is facing up.
    • Slide the battery release latch. The battery will pop up.
  2. HP Pavilion g7-1368dx  Hard Drive Replacement: passo 2, imagem 1 %32
    • Lift and remove the battery from its compartment.
  3. HP Pavilion g7-1368dx  Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Loosen the two Phillips #1 screws that connect the service panel to the device.
    • These are captive screws and cannot be fully removed. They will remain attached to the service panel.
  4. HP Pavilion g7-1368dx  Hard Drive Replacement: passo 4, imagem 1 %32
    • Slide the service panel down and pull it up to remove.
  5. HP Pavilion g7-1368dx  Hard Drive Replacement: passo 5, imagem 1 %32 HP Pavilion g7-1368dx  Hard Drive Replacement: passo 5, imagem 2 %32
    • Locate the hard drive.
    • It is missing from the device pictured here.
    • Disconnect the cable connector by pulling it away from the hard drive.
    • Remove the hard drive from the device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 312
