Introdução
This guide will give step by step instructions on how to remove and replace a WLAN Module in an HP Pavilion g7-1365dx. Use this guide if you are having trouble with the WLAN Module.
O que você precisa
Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
Push the switch above the battery towards the center of the laptop .
Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
Use the opening tool around the edges of the service door to loosen it and remove it.
Gently pull the black and gray coaxial connectors vertically up off of the module.
