Ir para o conteúdo principal
HP Pavilion g7-1365dx RAM Replacement
O que você precisa
  1. HP Pavilion g7-1365dx RAM Replacement, Battery: passo 1, imagem 1 %32
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx RAM Replacement: passo 2, imagem 1 %32
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx RAM Replacement, Service Door: passo 3, imagem 1 %32 HP Pavilion g7-1365dx RAM Replacement, Service Door: passo 3, imagem 2 %32
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx RAM Replacement, RAM: passo 4, imagem 1 %32 HP Pavilion g7-1365dx RAM Replacement, RAM: passo 4, imagem 2 %32
    • Use your fingers to simultaneously pull apart both tabs holding the module.
    • The memory module will pop up once the tabs are pulled so that it can be removed.
  5. HP Pavilion g7-1365dx RAM Replacement: passo 5, imagem 1 %32
    • Directly pull out the memory module as shown.
Conclusão
Rafal Szmyd
Membro desde: 03/22/19
181 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 294
