Introdução
This guide will give step by step instructions on how to remove and replace an optical drive in an HP Pavilion g7-1365dx. Use this guide if you're having issues with an optical drive that is faulty. This guide can also be used as a prerequisite guide for more involved replacements.
O que você precisa
Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
Push the switch above the battery towards the center of the laptop .
Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
Use the opening tool around the edges of the service door to loosen it and remove it.
Using the Phillips size 00 screwdriver, unscrew the 4.7 mm screw that holds the optical drive.
Use the opening tool to slide the drive out the side of the laptop to remove it.
