Ir para o conteúdo principal
HP Pavilion g7-1365dx Keyboard Replacement
O que você precisa
  1. HP Pavilion g7-1365dx Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • To prevent injury, make sure the laptop is powered off before removing the battery.
    • Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
    • Push the switch above the battery towards the center of the laptop .
  2. HP Pavilion g7-1365dx Keyboard Replacement: passo 2, imagem 1 %32
    • While pushing the switch, lift the battery by the side closest to the switch up and away from the laptop.
  3. HP Pavilion g7-1365dx Keyboard Replacement, Service Door: passo 3, imagem 1 %32 HP Pavilion g7-1365dx Keyboard Replacement, Service Door: passo 3, imagem 2 %32
    • Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
    • Use the opening tool around the edges of the service door to loosen it and remove it.
  4. HP Pavilion g7-1365dx Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 HP Pavilion g7-1365dx Keyboard Replacement, Keyboard: passo 4, imagem 2 %32
    • Remove the 4.7 mm screw that secures the keyboard to the computer using the Philips 00 screwdriver.
  5. HP Pavilion g7-1365dx Keyboard Replacement: passo 5, imagem 1 %32
    • Rest the laptop on its side so the optical drive is pointing up.
    • Insert the hex 2.0 screwdriver into the screw hole that had the 4.7 mm screw, press till the keyboard pops out.
  6. HP Pavilion g7-1365dx Keyboard Replacement: passo 6, imagem 1 %32
    • Turn the laptop right side up, facing you. Use the opening tool to help pull the keyboard towards you.
  7. HP Pavilion g7-1365dx Keyboard Replacement: passo 7, imagem 1 %32
    • Unplug the keyboard ribbon cable and remove the keyboard.
Conclusão
jonathan Rodriguez
Membro desde: 03/26/19
109 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Duração total: 462
